Knowledge Management
Experiencing role/index/restriction problem
pbnl
hi all,
i have an app with several dashboards, each displaying data from different indexes.
the users have roles assigned, which allow them to view different dashboards.
the roles allow access to different indexes.
some month ago, i've added a monitor that sends the data to the 'main' index using a datasource. now i'm asked to add a dashboard for this data and allow some users to use it. i've added a role, inherited the company base user role and capabilities, the index 'main' and a restriction to the datasource.
my testuser that only has this role can use the dashboard. BUT: as soon i add this role to other users, they can use this new dashboard, but not the otherones anymore. they simply say 'No results found.'
any ideas?
thanks...
Tags (2)
isoutamo
Hi
When you have added a search filter to any role and then you add that role to anyone else which have some other roles splunk merges those role definitions together. And this means that this search filter is added to all users which have this role. For that reason they cannot see anything else than this search filter allow.
My own suggestion is not to use any search filters as those usually generate more issues than solve! Also I try to avoid to use main/default index for anything. It's much easier to forward this kind of events to own index and then restrict access by index not by any search filter.
r. Ismo
pbnl
nobody any idea here?
isoutamo
Hi
r. Ismo
pbnl
hi,
this was my fear after i read the comment of richgalloway.
that's completely stupid, but it's like it is.
i'm fiddling already around with reindexing the files to a new index, but for some reason splunk will not do so 😉
there seems to be no way to make splunk forget about an already indexed file and reindex the same file to a new index. besides changing the first line of the file. this is not what i want to do.
maybe i'm going this way
thanks for bringing light in the dark 😉
isoutamo
richgalloway
Please tell us more about the "restriction to the datasource".  What kind of restriction?  It's possible this restriction is affecting access to other sources so the more you can tell us about the better we can help.
pbnl
the restriction i added when creating the role is:
sourcetype::log4jscan
when i click on 'Preview search filter results' i get:
index=main | search sourcetype::log4jscan
this give me the results i want. but running a search from an other role e.g.
index=msexchange OR index=srv066-vm OR index=srv067-vm OR index=ve2k8clu
doesn't return any results
Improve Delivery Assurance with S2S ACK for Edge Processor
Edge Processor helps Splunk customers process data closer to the source: filtering, transforming, masking, and ...
.conf26 Platform Sessions: Turn Machine Data into Agentic Action
As autonomous agents and multi-cloud architectures reshape modern IT, data platforms have to do far more than ...
Introducing the Launch of Edge Processor in Hybrid Mode!
Modernize Data Ingestion Without Starting Over  For years, organizations have relied on Splunk's proven ...
