Knowledge Management
how to add a duration column for each record, using its timestamp subtract the timestamp of the previous record,
wangkevin1029
Communicator
Hi, Splunkers,
I have a splunk search table as below, I want to add a duration column for each record, using its timestamp subtract the timestamp of the previous record,
for example, here for record 2, duration should be 2021-12-14 12:55:25.258  - 2021-12-14 12:55:03.339
_time                                               columna
2021-12-14 12:55:03.339   abc
2021-12-14 12:55:25.258   efg
2021-12-14 12:55:25.336   hij
any help would be appreciated.
Kevin
PickleRick
There's a bit easier solution relying on streamstats alone
<base search>| streamstats current=t window=2 range(_time) as duration
wangkevin1029
Communicator
thx for your quick response.
my table has its own sort,  so, not sure extra sort 0 _time will mess up original order?
I will give a quick try.
Kevin
wangkevin1029
Communicator
btw, since I use sort _time asc,  the time on top is earlier than time at the bottom
johnhuang
Motivator
Here's a possible solution:
| sort 0 -_time
| streamstats last(_time) AS end_epoch current=f
| eval end_time=strftime(end_epoch, "%Y-%m-%d %H:%M:%S")
| eval start_time=strftime(_time, "%Y-%m-%d %H:%M:%S")
| eval time_range=start_time." - ".end_time
| eval duration_sec=end_epoch-_time
| sort 0 _time
PickleRick
wangkevin1029
Communicator
Thank you, PickleRick,  it works perfectly, and more efficient,
really take some time to digest these amazing, also complicated parameters, syntax....
To johnhua,  your code also works beautifully, also learned new commands from your code.
Kevin
johnhuang
Motivator
Yep but he asked for this format "2021-12-14 12:55:25.258  - 2021-12-14 12:55:03.339"
PickleRick
You're right. I missed that. Just read "duration" 😉
wangkevin1029
Communicator
works perfectly,  thx you very much. you are a Splunk master
let me digest your code.... amazing.
Kevin
Career Survey
Index This | How many sevens are there between 1 and 100?
August 2025 Edition Hayyy Splunk Education Enthusiasts and the Eternally Curious!  We’re back with this ...
