Knowledge Management
Using per_second with summary index not working
techols
New Member
I have a saved search:
source=/opt/app/workload/MCRRepo/*/*.csv
| rex "(?.*),(?.*),(?.*),(?.*),(?.*),(?.*)"
| search componentName=ServiceComponent* measurementName=transactionAttempts
| sitimechart span=5m per_second(counterValue)
When I run the normal version of this query over a 24 hour period:
I get per_second ranges of up to 7000 TPS which matches the expected range of my data. But when I run the query against the summary index using the query over a 7 day or longer period:
index=summary search_name="MCR_TPS"
| timechart span=5min per_second(counterValue)
I get per_second ranges up to 200K. What am I missing? The TPS should still range up to 7000 TPS for each of the 7 days.
woodcock
Esteemed Legend
What is the timepicker window for the populating search that is dropping events into your summary index?
DalJeanis
Legend
try this
and this
index=summary search_name="MCR_TPS" | sitimechart span=5min per_second(counterValue)
Meet the .conf26 AI Agent Buildathon Winners
At the .conf26 AI Agent Buildathon, Splunk users turned their operational expertise into working AI agents ...
Trusted Autonomy in the SOC: A Maturity Journey
AI is compressing attacker timelines and pushing SOC teams beyond human capacity thresholds. The next SOC ...
Supercharging Windows Security Detection Performance: Introducing Hybrid Field ...
Windows event logs—from Security auditing and Sysmon to PowerShell script blocks—form the operational backbone ...
