Getting Data In
delete and create same index, data does not index
SplunkCSIT
Communicator
Due to some error, i had deleted the test123 indexes at indexer, restart the indexer, create the test123 again. But somehow the data does not index anymore?
Tags (1)
MuS
Hi SplunkCSIT,
Splunk keeps track of what was indexed and therefor does not re-index the same data again .... unless you do some work.
The radical method is to clean the fishbucket index. That will remove the memory of every files, be warned it will re-index all data.
  • on an indexer splunk clean eventdata -index _fishbucket
  • on a forwarder by removing the folder $SPLUNK_HOME/var/lib/splunk/fishbucket
You could selectively forgot a single file from the fish bucket like this:
splunk cmd btprobe -d $SPLUNK_HOME/var/lib/splunk/fishbucket/splunk_private_db --file $FILE --reset
You could manually re-index each file with the oneshot option
splunk add oneshot "/path/to/my/file.log" -sourcetype mysourcetype
You could modify the first line of the files to re-index, by default Splunk checks the first 256 chars of a file to differentiate them. If you had a simple comment on the first line it wil reindex it
You could change the crcSalt, create a new input for a new folder, add all the correct sourcetypes, etc... add the option crcSalt=<SOURCE> then move or copy the files to be re-index to the folder.
hope this helps ...
cheers, MuS
SplunkCSIT
Communicator
I got alot of indexes but i only want to remove one particular indexes, what will be the steps, thks a lot for assistance.
MuS
if your files will be read by an universal forwarder, than your forwarder fishbucket must be cleaned as well, after that your files will be re-indexed
SplunkCSIT
Communicator
I had deleted the indexes, if there a way to retrieve back instead of re-index each file manaully as i got more than 10000 of files? thks
HiroshiSatoh
Champion
Once captured logs will not be indexed. A new log is indexed.
New log is also not indexed?
Splunk Add-on for Microsoft Windows 11.0.3: Parse Once, Search Faster
The updated Splunk Add-on for Microsoft Windows helps customers search Windows events faster by reducing ...
What's New in Splunk Enterprise Security 8.8 and Beyond
Threats move at machine speed. Keeping up should not depend on having the biggest budget, the largest team, or ...
A Four-Part Event Series: State of Observability - Where AI Meets Performance
As AI agents take on more complex tasks, teams need greater visibility into how they behave, what they cost, ...
