Problem Starting Splunk web after enabling light forwarding
misteryuku
Communicator
Ever since i enabled light forwarding, i couldn't launch splunk web as normal. i double clicked the splunk.exe in windows 7 and there was this command line window that says.
Launching web browser pointing at SplunkWeb
waiting for splunk web to start.....
I have been waiting for a long time but the splunk web doesn't launch. How am i supposed to launch Splunk web now?????
Tags (2)
MHibbin
Influencer
Misteryuku,
When you enable SplunkLightForwarding, Splunk will change a configuration in one of the conf files to disable Splunk web. I don't think the starting splunkweb will work (tried it on my machine and it didn't work anyway). SplunkLightForwarding is basically an App, so it can be disabled (which will re-enable splunkweb).
To see the full output of CMD commands, you may need to CMD as administrator (e.g. right-click the CMD icon and select "run as administrator". Be careful of making other changes!
If you change to the Splunk bin directory (for example on my laptop this is "C:\Program Files\Splunk\bin") for example:
cd \Program Files\Splunk\bin
I would the run the following command to disable the app:
splunk.exe disable app SplunkLightForwarder
You will then need to restart splunk:
splunk.exe restart
... I followed that process and it worked for me.
Regards,
MHibbin
misteryuku
Communicator
i uninstalled Splunk and reinstalled Splunk before you replied me. i didn't mind uninstalling splunk and i am alright at resuming Splunk at its default state. The info you gave me would come in handy for me. Thanks.
Meet the .conf26 AI Agent Buildathon Winners
At the .conf26 AI Agent Buildathon, Splunk users turned their operational expertise into working AI agents ...
Trusted Autonomy in the SOC: A Maturity Journey
AI is compressing attacker timelines and pushing SOC teams beyond human capacity thresholds. The next SOC ...
Supercharging Windows Security Detection Performance: Introducing Hybrid Field ...
Windows event logs—from Security auditing and Sysmon to PowerShell script blocks—form the operational backbone ...
