Dashboards & Visualizations
How do I use Flow Map Viz add-on to design data flow between Splunk Server Components ?
dm1
Contributor
I am trying to develop a visualization showing Splunk distributed architecture with dataflow using Flow Viz App. I want to be able to show architecture as per below diagram with tcp_eps as Events/s.
To achieve this, I am looking at example 2 shown in the documentation section of the app. You can also find that example image on Splunkbase of the app  or if you have got the add-on on your local host, its link is most likely this  But I am quite confused with the instructions. It says, "Each node should be delimited by three hypens "---"." But where or how do I setup a query that will show link in that path syntax format ?
Another thing I am unsure is where it states,
<existing query> | append [|inputlookup my_table_of_nodes.csv]
Can someone please help me with this ?
Labels (4)
Splunk at Cisco Live 2025: Learning, Innovation, and a Little Bit of Mr. Brightside
Pack your bags (and maybe your dancing shoes)—Cisco Live is heading to San Diego, June 8–12, 2025, and Splunk ...
Splunk App Dev Community Updates – What’s New and What’s Next
Welcome to your go-to roundup of everything happening in the Splunk App Dev Community! Whether you're building ...
The Latest Cisco Integrations With Splunk Platform!
Join us for an exciting tech talk where we’ll explore the latest integrations in Cisco &#43; Splunk! We’ve ...
