Monitoring Splunk
Info from index=_internal does not match CMC ingest volume
tawm_12
Engager
Hello, dear Splunk Community.
I am trying to extract the ingest volume from our client's search head, but I noticed that I am getting different results depending on which method I am using.
For example, if a run the following query:
index=_internal source=*license_usage.log* type="Usage" | eval h=if(len(h)=0 OR isnull(h),"(SQUASHED)",h) | eval s=if(len(s)=0 OR isnull(s),"(SQUASHED)",s) | eval idx=if(len(idx)=0 OR isnull(idx),"(UNKNOWN)",idx) | eval GB=round(b/1024/1024/1024, 3) | timechart sum(GB) as Volume span=1d
I get the following table:
_time Volume
2024-11-25240.489
2024-11-26727.444
2024-11-27751.526
2024-11-28777.469
2024-11-29727.366
2024-11-30724.419
2024-12-01787.632
2024-12-02587.710
On the other hand, when I got to Apps > CMC > License usage > Ingest, and fetch the data for "last 7 days" (same as above) I get the following table:
_time GB
2024-11-25851.012
2024-11-26877.134
2024-11-27872.973
2024-11-28949.041
2024-11-29939.627
2024-11-30835.154
2024-12-01955.316
2024-12-02963.486
As you can see, there is a considerable mismatch between both results. So here's where I'm at a crossroad because I don't know which one should I trust. Based on previous topics, I notice the above query has been recommended before, even in posts from 2024.
I don't know if this is related to my user not having the appropriate capabilities or whatnot, but any insights about this issue are greatly appreciated.
Cheers, everyone.
dural_yyz
Motivator
I have always preferred the roll over summary generated once daily.
index=_internal source=*license_usage.log* type=RolloverSummary
https://docs.splunk.com/Documentation/Splunk/latest/Troubleshooting/WhatSplunklogsaboutitself
https://docs.splunk.com/Documentation/Splunk/latest/Admin/Shareperformancedata
tawm_12
Engager
This info actually matches the data from the CMC, the only issue I have is that you can't group the volume by index (although I can group by splunk_server/indexer).
Splunk Observability as Code: From Zero to Dashboard
For the details on what Self-Service Observability and Observability as Code is, we have some awesome content ...
Shape the Future of Splunk: Join the Product Research Lab!
Join the Splunk Product Research Lab and connect with us in the Slack channel #product-research-lab to get ...
