Knowledge Management
Help searching using eventtype and tags
johnward4
Communicator
I'm trying to tag specific data to a category name and only return data that matches the tag. For example,
index = bcoat_logs eventtype=my_Test_category | search tag=proxy | stats count by tag
I created an eventtype for "my_Test_category" and applied only the tag "proxy" to this but I am showing results for proxy, web, os, mail, usb, etc. Is it possible to use this method or do tag simply get ignored in SPL? Open to other suggestions as well
Thank you
woodcock
Esteemed Legend
If I understand you correctly, you would like your events to ONLY show those eventtypes that are owned by YOU. If so, just add this to the bottom of your search (be sure to replace the <*****INSERT YOUR SPLUNK LOGIN HERE*****>😞
... | eval eventtype = mvfilter(match(eventtype, [| rest/servicesNS/<*****INSERT YOUR SPLUNK LOGIN HERE*****>/-/configs/conf-eventtypes splunk_server=local
| table title
| format "" "" "" "|" "" ""
| rex field=search mode=sed "s/title=//g s/\"//g s/ //g s/^/\"/ s/\|?$/\"/"
| return $search]))
| table eventtype
johnward4
Communicator
I return 5 different tags even though I'm querying a new eventtype I created that only has the tag "proxy" attached to it..
index=* eventtype="Web_Proxy_Web_Filtering" | search tag="proxy"alt text
nareshinsvu
Builder
proxy in double quotes not helping?
| search tag="proxy"
Integrating Splunk Search API and Quarto to Create Reproducible Investigation ...
 Splunk is More Than Just the Web Console For Digital Forensics and Incident Response (DFIR) practitioners, ...
