Splunk Dev
top 10 values of fields and percentage using sdk (Similar to fields on UI)
pratik151
New Member
In the splunk UI on the left hand side after the query search you can find the fields and the top 10 values, (their percentage and count) for all the fields.
I would like to use this programatically, Is there any way I can get it using splunk sdk. Or any query that would give the same result.
Thanks in advance.
woodcock
Esteemed Legend
It leverages the top (and rare) command.
martin_mueller
It does? 😮
woodcock
Esteemed Legend
martin_mueller
The field sidebar in the UI doesn't run infinitely many top commands.
woodcock
Esteemed Legend
True enough.
martin_mueller
.conf24 | Registration Open!
Hello, hello! I come bearing good news: Registration for .conf24 is now open!   conf is Splunk’s rad annual ...
ICYMI - Check out the latest releases of Splunk Edge Processor
Splunk is pleased to announce the latest enhancements to Splunk Edge Processor.  HEC Receiver authorization ...
Introducing the 2024 SplunkTrust!
