Dashboards & Visualizations
How do I use Flow Map Viz add-on to design data flow between Splunk Server Components ?
dm1
Contributor
I am trying to develop a visualization showing Splunk distributed architecture with dataflow using Flow Viz App. I want to be able to show architecture as per below diagram with tcp_eps as Events/s.
To achieve this, I am looking at example 2 shown in the documentation section of the app. You can also find that example image on Splunkbase of the app  or if you have got the add-on on your local host, its link is most likely this  But I am quite confused with the instructions. It says, "Each node should be delimited by three hypens "---"." But where or how do I setup a query that will show link in that path syntax format ?
Another thing I am unsure is where it states,
<existing query> | append [|inputlookup my_table_of_nodes.csv]
Can someone please help me with this ?
Labels (4)
Get Schooled with Splunk Education: Explore Our Latest Courses
At Splunk Education, we’re dedicated to providing incredible learning experiences that cater to every skill ...
Splunk AI Assistant for SPL | Key Use Cases to Unlock the Power of SPL
Splunk AI Assistant for SPL | Key Use Cases to Unlock the Power of SPL  The Splunk AI Assistant for SPL ...
Buttercup Games: Further Dashboarding Techniques (Part 5)
This series of blogs assumes you have already completed the Splunk Enterprise Search Tutorial as it uses the ...
