Archive
Highlighted
Problem using multikv to parse tabular data
Motivator
Hello!
I'm trying to create a custom multikv.conf stanza for the first time, and am having trouble getting it working. Here is an example of the events I'm working with:
Object ID Volume                    Aggregate     Storage Server          Daily Growth Rate   Days To Full Daily Growth Rate (%)
36906     volume_1                  aggr1_vmw_sas nas-vmw-prod02.foo.com           1074009984            1                  10.0
25031     volume_2                  aggr2_vmw_sas nas-vmw-prod03.foo.com             29670000           75                   0.6
25033     volume_3                  aggr2_vmw_sas nas-vmw-prod03.foo.com             23464000          146                   0.4
5430      volume_4                  aggr1_vmw_sas nas-vmw-prod02.foo.com             22181400          273                   0.3
Totals        1249102095
The multikv.conf stanza I created is as follows:
[volume_growth_rates]
#ignore the first two lines, as getting proper tokens with the spaces and % will be problematic
pre.start = "Object"
pre.linecount = 2
pre.ignore = _all_
#Manually define the header tokens
header.tokens = _token_list_, ObjectId, Volume, Aggregate, StorageServer, DailyGrowthRate, DaysToFull, DailyGrowthRatePct
#tokenize with space separators
body.end = "Totals"
body.tokens = _tokenize_, 0, " "
#ignore the 'Totals' line, as it doesn't really contain useful data.
post.start = "Totals"
post.linecount = 1
post.ignore = _all_
When I try to use this in search, nothing happens. Trying both:
... | multikv
and
... | multkv conf=volume_growth_rates
Any ideas on what I'm missing here?
Tags (2)
Highlighted
Re: Problem using multikv to parse tabular data
Splunk Employee
Splunk Employee
Tested in v6.0.
multkv.conf is annoying.
It is acting funny. We cannot trust the spec file.... sad. Examples do not work....
Solution 1. Forget about multikv.conf and use general Field Extraction
  • props.conf
    [source::.../Log/testmultikvtable.log]
    REPORT-multikv = testmultikvtable1 testmultikvtable2
  • transforms.conf
    [testmultikvtable1]
    REGEX = ^((\d+)\s+(\S+)\s+(\S+)\s+(\S+)\s+(\S+)\s+(\S+)\s+(\S+))
    FORMAT = Row::$1 objectID::$2 volume::$3 aggregate::$4 storageServer::$5 dailyGrowthRate::$6 daysToFull::$7 growthRate::$8
    MV
    ADD = true
    [testmultikvtable_2]
    REGEX = ^Totals\s+(\S+)
    FORMAT = Totals::$1
Solution 2. Stick with buggy multikv.conf
# Put multikv.conf in all of Splunk instance (Search Head and Peers)
- props.conf
[source::.../Log/test_multikv_table.log]
LINE_BREAKER = ([\n\r]+)Object ID
SHOULD_LINEMERGE = false
DATETIME_CONFIG  = CURRENT
KV_MODE = multi_volumeGrowthRates
  • multikv.conf
    Bug: must be located in Search Peer's local directory, instead of bundle from SH
    [volumeGrowthRates]
    Not sure if "pre" is working
    pre.end = "----.*"
    pre.linecount = 2
    pre.ignore = all
    header setting
    header.tokens = tokenlist_,"ObjectId","Volume","Aggregate","StorageServer","DailyGrowthRate","DaysToFull","DailyGrowthRatePct"
    Body needs to set ignoring pre and post lines
    body.tokens = tokenize, 0, " "
    body.ignore = regex "----|Totals"
    Post... ignore is not working???
    post.linecount = 1
    post.ignore = all
Highlighted
Contributor
Maybe it is issue with identifying the header?
How does SPLUNk know when to ignore the header here?
example with the manual approach of assigning headers, we specify start of header & linecount:
# specify table header location and processing
header.start = "Object ID"
header.linecount = 1
header.tokens = _tokenize_, -1," "
