Need help with a greater than in seconds
trehman
New Member
My search alert filter: host=web-* "\"response_code\": 5*," OR "\"message\": \"Application Error\"" OR "\"response_code\": 0"\"total_time\" userloans
QUESTION. I need to modify my alert so it captures all responses that has greater than total_time of 9 secs (below sample). What should I add to capture this to my alert above? Any help would be great!
E, [2017-02-11T03:09:33.426066 #58] ERROR -- : {
"url": "http://12345/A.v.x455.adfadfr.co/loans/userloans",
"method": "get",
"request_headers": {
"Content-Type": "application/json",
"client_ip": "[FILTERED]",
"request_body": null,
"response_code": 0,
"response_body": "",
"total_time": 9.0,
"starttransfer_time": 0.0,
"appconnect_time": 0.0,
"pretransfer_time": 0.0001,
"connect_time": 0.0,
"namelookup_time": 0.0,
"redirect_time": 0.0
Tags (1)
gokadroid
Motivator
Hope this helps:
host=web- "\"response_code\": 5," OR "\"message\": \"Application Error\"" OR "\"response_code\": 0"\"total_time\" userloans
| rex field=_raw "\"total_time\":\s*(?<totalTime>[^,\s]+)"
| where totalTime > 9
pradeepkumarg
Influencer
If you don't have it already, you need to extract the total time into a field like below and filter on it
your base search | rex "(?i)\Wtotal_time\W{2}(?P<TOTAL_TIME>\.\S+)\," | where TOTAL_TIME > 9
The above rex might not be perfect, but you get the idea
.conf24 | Registration Open!
Hello, hello! I come bearing good news: Registration for .conf24 is now open!   conf is Splunk’s rad annual ...
ICYMI - Check out the latest releases of Splunk Edge Processor
Splunk is pleased to announce the latest enhancements to Splunk Edge Processor.  HEC Receiver authorization ...
Introducing the 2024 SplunkTrust!
