Archive
Monitor doesn't work with env variable in inputs.conf
Splunk Employee
Splunk Employee
I observed that none of the log files are not indexed into Splunk when I used the environment variable, in my case it's the Windows OS "$PROGRAMFILES" env variable. An example is as below:
[monitor://$PROGRAMFILES\logs\st*Server.log]
and there are two files in logs folder "startServer.log" and "stopServer.log".
However I noticed a different behavior when I used
[monitor://C:\Program Files\logs\st*Server.log]
Both "startServer.log" and "stopServer.log" are indexed into Splunk.
Is this a known limitation to only use the absolute path in the inputs.conf to monitor log files?
Builder
There is an example of this being used in the windows app. Looking at Win 2k8 environment variables I see a system variable of "windir". This leads me to believe it must be a system variable (or perhaps a user variable matching the user running the splunkd service), and is case insensitive.
[monitor://$WINDIR\WindowsUpdate.log]
sourcetype = WindowsUpdateLog
disabled = 1
Splunk Employee
Splunk Employee
No. In fact, Splunk itself uses the $SPLUNK_HOME environment variable, and I have used Windows (and Unix) environment variables at other times in the monitor stanza headers. First, make sure that that variable is actually set. Also, I don't know if you need to specify it as $ProgramFiles, rather than $PROGRAMFILES. Finally, maybe there's a problem when you try to use environment variables with a wildcard (this seems likely) in which case you should probably specify the parent directory and the whitelist explicitly.
Super Champion
Just again, FYI. When I upgraded these forwarders to 4.1.3, I had problems with BOTH of my previously provided examples. I'm now using the whitelist approach instead. (So it appears that there is some difference between how this worked in 4.0 and 4.1)
Super Champion
For whatever it's worth, I have inputs stanzas that uses an environment variables, an alternate groups, and wildcards without any issues. Here are two examples that are working fine on a 4.0.11 install: [monitor://$SPNK_WMHOME\MWS\server\default\logs\20*_*\(_full_|install).log] and [monitor://$SPNK_WMHOME\IntegrationServer\logs\(server|stats|error|security)*.log*]
Splunk Employee
Splunk Employee
i'll try adding "whitelist" in the monitor stanza and see how things go
Don’t Miss Global Splunk
User Groups Week!
Free LIVE events worldwide 2/8-2/12
Connect, learn, and collect rad prizes
and swag!
