Archive
ML Toolkit and Showcase problems after upgrade to 6.4
After upgrade to 6.4 I can't see follows at Predict Numeric Fields dashboards:
1. Raw Data Preview is empty;
2. Fit Model Parameters Summary is empty;
3. Actual vs. Predicted Overlay is empty.
Links "Create New Model" and "Load Existing Settings" doesn't work as well.
Whats the problem?
Dear All.
After I press F5(Refresh) all features appear.
Problem have solved)))
Dear All.
Slider which define backet size on "Residuals Histogram" panel disappear as well.
I use Windows installation of Splunk.
I've upgraded Python for Scientific Computing to version 1.1 and ML Toolkit and Showcase to version 1.0.
I've also upgrade Python for Scientific Computing to version 1.1 and ML Toolkit and Showcase to version 1.0.
State of Splunk Careers
Access the Splunk Careers Report to see real data that shows how Splunk mastery increases your value and job satisfaction.
Find out what your skills are worth!
