Is there a max number for MAX_EVENTS?
Nicholas_Key
Splunk Employee
Splunk Employee
I didn't find it mentioned anywhere in the documentation. I might have overlooked it.
http://www.splunk.com/base/Documentation/latest/admin/Propsconf
Tags (1)
Stephen_Sorkin
Splunk Employee
Splunk Employee
If you find yourself setting MAX_EVENTS to be very large, you should probably consider changing the LINE_BREAKER to break the input stream into larger chunks (that aren't single lines).
At index time, data is broken into lines (usually by \r\n or \n). It then may be put back together using line merging. It's significantly more efficient to not have to reassemble the data with string concatenation. You then have to set the maximum "line" length using the TRUNCATE attribute. If you know that every event is demarcated by two newlines, you could set in props.conf:
[<sourcetype>]
LINE_BREAKER = ((\r?\n){2})
TRUNCATE = 1000000
SHOULD_LINEMERGE = false
gkanapathy
Splunk Employee
Splunk Employee
Extending Observability Content to Splunk Cloud
Watch Now!   In this Extending Observability Content to Splunk Cloud Tech Talk, you'll see how to leverage ...
More Control Over Your Monitoring Costs with Archived Metrics!
What if there was a way you could keep all the metrics data you need while saving on storage costs?This is now ...
New in Observability Cloud - Explicit Bucket Histograms
Splunk introduces native support for histograms as a metric data type within Observability Cloud with Explicit ...
