I have data in json format as following:-
{Run=1 , Average=2.1, Max=3, Min=1.4, Transaction=Sample1}
{Run=1 , Average=2.1, Max=3, Min=1.4,Transaction=Sample2}
{Run=2 , Average=2.3, Max=3.1, Min=1.5,Transaction=Sample1}
{Run=2 , Average=2.3, Max=3.1, Min=1.5,Transaction=Sample2}
{Run=3 , Average=2.6, Max=3.2, Min=1.6,Transaction=Sample1}
{Run=3 , Average=2.6, Max=3.2, Min=1.6,Transaction=Sample2}
I want to compare all the fields with each other for the top 2 Run Values.
The below query is getting the data in the format I exactly need but i'm not able to pass Run Values via query dynamically:-
index=pt sourcetype=_json | search Run=3 |rename Average as "Average1" | rename Maximum as "Max1"| join Transaction type=inner[ search index=pt sourcetype=_json | search Run=2 |rename Average as "Average2" | rename Maximum as "Max2"| table Transaction, Average2] |table Transaction, Average1,Average2,Max1, Max2
Result:-
Transaction Average1 Average2 Max1 Max2
Sample1 2.6 2.3 3.2 3.1
Sample2 2.6 2.3 3.2 3.1
How to capture the second max value for a field like Run and get the desired results?
@pratyushak can you try the following:
| sort 0 - Transaction Max
| streamstats count by Transaction
| search count IN (1,2)
| chart list(Average) as Average list(Min) as Min list(Max) as Max list(Run) as Run by Transaction
| foreach Average Max
[ eval "<<FIELD>>1"=mvindex('<<FIELD>>',0),"<<FIELD>>2"=mvindex('<<FIELD>>',1)]
| table Transaction Average1, Average2, Max1, Max2
Following is a run anywhere example based on the sample data provided:
| makeresults
| eval data="{\"Run\":1,\"Average\":2.1,\"Max\":3,\"Min\":1.4,\"Transaction\":\"Sample1\"};{\"Run\":1,\"Average\":2.1,\"Max\":3,\"Min\":1.4,\"Transaction\":\"Sample2\"};{\"Run\":2,\"Average\":2.3,\"Max\":3.1,\"Min\":1.5,\"Transaction\":\"Sample1\"};{\"Run\":2,\"Average\":2.3,\"Max\":3.1,\"Min\":1.5,\"Transaction\":\"Sample2\"};{\"Run\":3,\"Average\":2.6,\"Max\":3.2,\"Min\":1.6,\"Transaction\":\"Sample1\"};{\"Run\":3,\"Average\":2.6,\"Max\":3.2,\"Min\":1.6,\"Transaction\":\"Sample2\"}"
| makemv data delim=";"
| mvexpand data
| rename data as _raw
| spath
| foreach Average Max
PS: Commands from makeresults
till spath
are used to generate JSON data as per the question.
@pratyushak,
Another approach could be using dedup
. The result is based on max Run
value. If you want max of any other fields, you can add them into the sortby
part of dedup
| dedup 2 Transaction sortby -Run |streamstats last(*) as *1 by Transaction current=f
| rename Average as Average2,Max as Max2,Min as Min2| where isnotnull(Average1)
| foreach Average Max
| makeresults
| mvexpand data
| rename data as _raw
| spath
| foreach Average Max
till spath
