Archive
Hi, please help me asap if possible. I'm using splunk could and having access to search head. Is there any search query to find out indexing and EPS rate.
Rody333
New Member
Tags (1)
elliotproebstel
Champion
Here are some queries supplied by @martin_mueller in an older post.
 index=_internal component=metrics TERM(group=thruput) | timechart per_second(ev) by splunk_server
 index=_internal component=metrics TERM(group=thruput) | timechart avg(instantaneous_eps) by splunk_server
He suggests that the two may produce very different metrics if your server isn't on all day.
elliotproebstel
Champion
Have you had a chance to try these queries? Did they work for you?
Rody333
New Member
Yes, I got results. Just to confirm: 1st query is to get indexing rate in kbps and 2nd query is to get "event per second'. Please correct me.
elliotproebstel
Champion
According to @martin_mueller, both of these should be outputting events per second.
Rody333
New Member
okay, but both giving different results like 1st query giving 200,210 etc and 2nd query giving 3,4, etc. I'm little confused which 1 to agree for.
somesoni2
Revered Legend
Do you've DMC configured on your search head? If you do, you can see all metrics about indexing in the indexing performance dashboard in there.
http://docs.splunk.com/Documentation/Splunk/7.0.3/DMC/IndexingDeployment
Rody333
New Member
I don't have privilege for DMC.. only I have is Search head with limited privilege. So, if you can help me with any search query can get me desired result.
Take the 2021 Splunk Career Survey
Help us learn about how Splunk has
impacted your career by taking the 2021 Splunk Career Survey.
Earn $50 in Amazon cash!
